Please help with the following:
I need create a filter to put in a sprint table , which filtrate the "story" type incidents in a specific state ex: "Development" and so likewise look the sub-task of each parent incident, since I make a filter, which allows me to see the parent incidents, but not the subtasks of each one in a sprint table.
When doing the filter it appears to me in the following way and I need that only the incidents appear in the "DEVELOPMENT" state, but that the tasks continue to appear.
Milena G
Hi Milena,
Just to clarify, do you want an JQL query, that will return your stories, that have sub-tasks and that are in a specific status, but not return their sub-tasks, is that right?
Hi Gabriel
Thanks for you answer,
I need the filter to allow the issues of a specific type of incident in a state determined for example in "Development" and that allow to see with the tasks inside, all the above within the board. Because if I use a filter like this: Project = MSBAN AND issuetype in (Historia) AND status = DESARROLLO on the board it no longer allows me to display related tasks within the issue:
Milena G
