×All is in the question :)
Hi @Claudio Gomes ,
if you mean tickets that were resolved in the last 24 hours, you can use this :
resolved >= -24h
Let me know if this helps,
--Alexis
Thanks for your reply but that's not what I'm looking for. I want a filter that would give me tickets that were resolved within 24 hours of being created.
I don't think it's possible to get this using JQL. You will need an addon, like Automation for Jira or Scriptrunner.
Indeed scriptrunner seems to be able to do that with "datecompare".
Thanks for your help.
Have a good day.
Consider Automation and either a custom field or label.
trigger - issue transitioned
condition - check if issue resolved
Action - using date math determine if resolution date is within 24h if so set label or CF
