×Hello.
I have a problem with JQL query.
I would like to create a filter that will list story issues that have linked epic issues but only epics that are in progress and done.
I don't seem to figure it out.
Any ideas?
Thank you.
I’m Charlotte, a support engineer at Appfire and I’m here to help you.
Unfortunately, using vanilla JQL, you’ll not be able to do it dynamically.
In the app where my team works, JQL Search Extensions for Jira, you can use this query to find stories whose epics are in progress or done:
issue in childrenOfEpicsInQuery("status in ('in progress', done)") AND type = Story
Please contact our support if you have any other questions about this query.
We’ll be happy to help you!
Okay, so without some kind of extensions for JQL I won't be able to search for issues as I would like to.
Thanks, I will keep this solution in mind.
Unfortunately, this is trickier than one might think; as a hierarchical query, it would really require some kind of join or subquery, which isn't available in plain Jira/JQL.
A few directions forward:
If you want to run your search dynamically, without manually "stitching" two queries together, you'll need extra tooling:
Hope this helps,
Best,
Hannes
Just to expand on the last point, this is how this would look in the app that my team and I are working on, JXL for Jira. Put simply, you'd create a sheet with all issues that are potentially relevant to you, enable the default issue hierarchy (that's just one click), and then use JXL filtering capabilities to narrow down to the issues that you care about:
Once you have your list of issues, you can work on these directly in JXL (much like you'd do in e.g. Excel or Google Sheets), trigger various operations in Jira, or export them for further processing.
Any questions just let me know!
