Hey All,
I have a query to find all issues which were transitioned from one status to other by an automation rule.
Like
project = ABC and statusCategoryChangedDate < startOfDay(-7) AND status changed by "automation for Jira".
I also tried the user id "56777:f58131cb-b67d-43c7-b30d-6b58d4129jh077"
In both the cases, there is no syntactical error but I don't get any results back.
Any advice is appreciated.
I was able to get it to work using the cryptic userid so I'm thinking that there are no issues matching your query. Have you verified you have an issue that should?
can you try to simplify things a bit, e.g.
status change by "56777:f58131cb-b67d-43c7-b30d-6b58d4129jh077"
as long as you have any issue in any project where the status changed via A4J it should return results. If not then let's verify the A4J userid. find an issue that indeed changed status, click on the history tab to find the details, click on the automation for jira and in the profile popup click view profile. inspect the URL for the userid.
You are correct. I technically had automation making changes but not really transitioning the tickets. Validating this actually worked.
Thanks!
