Hi!
I'm trying to get all issues, which has been done after a specific date, but for a some reason my JQL doesn't work in Jira Cloud (Next-Gen Project). JQL expression is following:
project = "ProjectName" AND status changed to Done after "2019-01-01" AND issuetype = Bug
I could debug that "changed to Done" is the problem: if I drop "to Done" it works fine. It work in Jira Server version, so I think, maybe the problem is related to next gen project?
I have also seen this problem with issues in Next Gen projects.
You cannot use "changed from" or "changed to" with Next Gen projects. Atlassian has not implemented it, and has no plans to do so, and has not documented anywhere that this gap between the two types exists.
I urge anyone reading this to reconsider using Next Gen projects. There must be dozens of gaps like this that Atlassian probably doesn't even realize they haven't closed because they obviously don't proactively monitor these forums.
DO NOT USE NEXT GEN
