JQL for Linked issues in another project
Kelly Hansen May 14, 2024
Does anyone know how to do a JQL to show all my issues that have a linked issue from another project?  I seem to only be able to search for a specific linked issue and I dont want to do that as we are trying to build our list for scrum of scrums.  I keep trying to do below and it does not work.
Project = Family and linkedissue ~ "Houses*"
Chris Rainey
Hey Kelly,
Someone may correct me here but I don't believe this is natively possible. To pull this off, I think you'd need an add-on, such as Scriptrunner.
Hannes Obweger - JXL for Jira
Hi @Kelly Hansen
to the best of my knowledge, @Chris Rainey is correct that this isn't possible natively. The only built-in solution that I can think of is to somehow use Jira Automation to read and process your issues' issue links, and write the result into a custom field; you could then filter by this custom field.
Alternatively, if you're open to solutions from the Atlassian Marketplace, there are apps that can help with this. E.g., I believe that your use case would be easy to solve using the app that my team and I are working on, JXL for Jira.
JXL is a full-fledged spreadsheet/table view for your issues that allows viewing, inline-editing, sorting, and filtering by all your issue fields, much like you’d do in e.g. Excel or Google Sheets. It also comes with a number of so-called smart columns that aren’t natively available, including linked issues, along with many other issue-link-related columns. As you can apply text filtering (including logical operators like OR) to all your columns, you can perform a search like e.g. this in just a couple of clicks:
JXL also comes with a number of advanced features, including support for (configurable) issue hierarchies, issue grouping by any issue field(s), sum-ups, or conditional formatting. With these, you can also model much more sophisticated queries and reports that he one above.
Best,
Hannes
nreddy
April 29, 2025
Thanks @Hannes Obweger - JXL for Jira , using JXL worked much better than using script runner. The script runner query was strangely VERY slow.
Hi @nreddy,
thank you for your kind words - great to hear that JXL works so well for you! Please don't hesitate to reach out to us at https://support.jxl.app if there's anything we can assist with!
Like nreddy likes this
Amay Purohit_RVS
May 15, 2024
Hi @Kelly Hansen
Since you are on Jira Premium, did you try out Roadmaps. I am not sure if it can be achieved in Roadmaps but you can give it a try. Or alternatively, if you would be interested in an add-on for this need, you can try out our plugin.
Issue Hierarchy
The app shows your issue hierarchy in a tree view created through Issue Links. The Issues in the tree can be in multiple projects and the app will pull out each one of them and show you a structured hierarchy.
The app has multiple other features which are very useful in project tracking and management. Do give it a spin.
(Disclaimer: I work on RVS, the vendor for this app)
Kelly Hansen May 16, 2024
unfortunately roadmaps shows me too much detail.  But I am going to give this a try and see if I can get it to work
Like Amay Purohit_RVS likes this
