JQL for Test case executed by specific members based on date?
Welcome to the community.
What app are you using form Test Management, is this app making use of work types/issue types in Jira?
Or does it works in its on menu, then probably it has no JQL features.
Go over the documentation of the app to see if the app offers JQL functions, and if so, which
I am using Zephyr plugin in Jira
Then you can only search or report in the Zephyr app menu in Jira, you won't be able to use the default basic or advanced JQ:L option as Zephyr has no JQL options available
