I'm working on a filter that'll show issues that you should review. I'd like to achieve that it'll show issues if any of the following match:
Note that this excludes issues that are in a project led by you but that have only components selected that are led by somebody else.
I'm here currently with my JQL:
status = Done
AND assignee != currentUser()
AND ((project IN projectsLeadByUser() AND component IS EMPTY) OR component IN componentsLeadByUser())
ORDER BY updatedDate ASC
This fits criteria #1 and #3 but not #2. I'd essentially need something like componentsLeadByUser(EMPTY) (but this is not available).
Do you have a suggestion on how to achieve #2? Thanks in advance!
I do not believe that is possible with out-of-the-box JQL features.
The function componentsLeadByUser() assumes the current user when no one is specified, and there does not appear to be a function to find the inverse: find all components without a lead...which are assigned to issues.
And because components are project-specific, I do not believe there is an easy way to gather all of the components without leads for use in a hard-coded query, such as component IN (noLeadComponentA, noLeadComponentB, etc.)
Your query may require a marketplace addon to enhance features of JQL or reporting.
I see, thank you. Do you happen to know if an add-on would support something like this? I looked through the JQL-related add-ons in the Marketplace, and JQL Tricks Plugin with jqlt.components.leads might; I've written them to chime in here. I couldn't find any other.
I do not know of any specific ones. For the marketplace ones you find, they each have a support tab showing their documentation. I recommend taking a quick look/search of those to see what is available to help.
Yeah, that's what I did and how I arrived at the mentioned JQL Tricks Plugin. I'll wait for their answer.
It's not possible with that add-on either right now, but it's a feature that can possibly be added. So, for now, the overall answer is "this isn't possible, not even with an add-on".
