JQL query to filter issues in Project A which are linked and replaced by issues in Project B
Vineet_Kotian June 14, 2023
The project A I am referring to is an old project which has to be retired soon. All of its issues need to be migrated to Project B.
As part of this migration:
1. Project A issues are marked as "Retired" in the status
2. New issues are created in Project B
3. For future traceability, Project A issues are linked to these new issues in Project B under "is replaced by".
I am looking out for a jql filter to search for Project A issues that have not gone through the above process so that I can export them, feed them in a new csv template and bulk import them in Project B all at once.
Please suggest if there are any alternate better options?
Trudy Claspill
Hello @Vineet_Kotian
You say you want to select issues that have not gone through the process. How do you know which ones have not gone through the process?
Are they in a status other than "Retired"?
Or are then in the "Retired" status but don't have a link to an issue in Project B?
Would one of these issues in Project A ever have a link "is replaced by" to any other issue than the replacement issue in Project B?
Hello @Trudy Claspill
Thanks for responding.
Yes the issues which have not gone through the process are in statuses other than "Retired" + they wont have a link to an issue in Project B with type "is replaced by".
What they might have is a link to Project C or D with type "relates to" or "Blocks" etc.
The link "is replaced by" is only used to link the replacement issues in Project B and not any other issue or project.
Trudy Claspill
project="Project A" and status != "Retired" and (not issuelinktype = "is replaced by" or issuelinktype is empty)
That will get you all issues from Project A that are not in the status "Retired" and that either have not links to other issues or do have links but none of the links are "is replaced by".
Vineet_Kotian June 18, 2023
Thats Awesome @Trudy Claspill . This filter gives the desired result.
Appreciate your help!
Like Trudy Claspill likes this
