JWM - Issue type scheme Update Help
Elif Alverson
We are using a JWM project template to create new projects. It is pulling the same screens and schemes from the template for the new projects as expected.
However when I try to use a different issue type screen scheme , I do not see the issue type screen scheme I wanted to use. I had to create a new issue type screen scheme which is auto named "New issue type scheme for project X Project Template". Is there a way to use an exiting issue type screen scheme? If not how to rename this one? I also noticed this scheme uses the main project template field configuration that I would like to change. Any way to do that?
Thank you.
John Funk
Hi Elif,
Is this a Company-managed JWM project? If you go to Settings > Issues > Issue Type Schemes do you see the new scheme you want to use instead?
If all of that is yes, do you go to Project Settings > Summary and then click on the Issue Type Scheme name?
And once there then click Action drop down on the upper right and choose Use a different scheme.
Elif Alverson
Thank you!
Like John Funk likes this
