Hi
I've started using a JWM Project Management team-managed project and its suiting me well, but for some reason, its putting all sub task child issue sub-tasks at the bottom of the timeline as well as under the parent task which makes no sense as they look like more tasks, they arent even indented like they are when visible under their parent.
Is this meant to happen and is there a way to stop JWM from doing this?
Stephen
Hi Stephen,
This appears to be a bug that has been introduced. You should report it here:
