I have a custom field with a help dialog that runs using the javascript outlined in https://confluence.atlassian.com/jira064/creating-help-for-a-custom-field-720412166.html It works fine on the Create Issue screen, but on the Edit screen nothing happens when the question mark icon is clicked.
Here is the script:
SB and RRT Descriptions
<script type="text/javascript">
function showHelp() {
var listenersDiv = document.getElementById("qaFieldHelp");
if (listenersDiv.style.display == 'none') {
listenersDiv.style.display = '';
} else {
listenersDiv.style.display='none';
</script>
<a href="#" onclick="showHelp(); return false;"><img src="/images/icons/ico_help.png"/></a>
<div id="qaFieldHelp" style="display:none">
Help Text
</div>
Any thoughts on how I could get this to work on the Edit screen?
Add id attribute to your <a> tag,for example "myLink".
Try to add this to your script:
JIRA.bind(JIRA.Events.NEW_PAGE_ADDED, function () {
$("#myLink").click(function () {
showHelp();
My script currently looks like:
} else {
showHelp();
</script>
<a id="myLink" href="#" onclick="showHelp(); return false;"><img src="/images/icons/ico_help.png"/></a>
Help Text
</div>
And still does not work on edit. Any thoughts?
You are right, needed to add something more "setTimeout"
Your code should look like this:
setTimeout(function() {
showHelp();
}, 0);
Also, for the safe side, put your html tags first and your script in the end (currently it's the other way around)
So right now my script looks like this and still does not work on the edit screen (but does on the create screen):
Help Text
</div>
} else {
showHelp();
}, 0);
</script>
(note that I had to add a close parentheses and bracket to your code block)
Any other thoughts on how I could get this to work? It's strange because if I manually run this in the console when the edit screen is open:
} else {
the javascript functions normally on click.
This should work, i tried the same and worked for me.
Try to add debugger and open dev tool (F12) to see what happen in your code:
function showHelp() {debugger;
} else {
JIRA.bind(JIRA.Events.NEW_PAGE_ADDED, function () {debugger;
$("#myLink").click(function () {debugger;
showHelp();
}, 0);
