Jira 运行一段时间后就卡死,无法访问,需要你的协助去解决这个问题
ydwang@gxatek.com January 3, 2022
您好 ,最近公司的Jira 服务经常出现挂死的现象, 无法访问Jira , 这里需要重启Jira 才能恢复,需要远程支持。今天的运行正常。
Ollie Guan
Hi ydwang@gxatek.com ,
Welcome to the community!
这是一个系统层级的问题,需要你提供更多的信息,例如系统日志。
出于隐私考虑,这部分信息不建议在社区直接讨论。
如果你的许可证仍在维护内,建议直接联系你采购时通过的合作伙伴,或者联系Atlassian的服务台。
Partners
https://www.atlassian.com/partners
Contact Support Team, Submit a request below.
https://support.atlassian.com/contact/#/
 catalina.out  logs  有报错,只有有下列的报错,Jira 就不可用了
04-Jan-2022 15:24:55.272 WARNING [ContainerBackgroundProcessor[StandardEngine[Catalina]]] org.apache.catalina.valves.StuckThreadDetectionValve.notifyStuckThreadDetected Thread [http-nio-8080-exec-208] (id=[894]) has been active for [123,163] milliseconds (since [1/4/22 3:22 PM]) to serve the same request for [http://223.244.84.116:8080/rest/api/2/issue/A58A88GOS2-3941/attachments] and may be stuck (configured threshold for this StuckThreadDetectionValve is [120] seconds). There is/are [92] thread(s) in total that are monitored by this Valve and may be stuck.
java.lang.Throwable
at sun.misc.Unsafe.park(Native Method)
at java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215)
at java.util.concurrent.locks.AbstractQueuedSynchronizer.doAcquireSharedNanos(AbstractQueuedSynchronizer.java:1037)
at java.util.concurrent.locks.AbstractQueuedSynchronizer.tryAcquireSharedNanos(AbstractQueuedSynchronizer.java:1328)
at java.util.concurrent.CountDownLatch.await(CountDownLatch.java:277)
at org.apache.tomcat.util.net.NioEndpoint$NioSocketWrapper.awaitLatch(NioEndpoint.java:1160)
at org.apache.tomcat.util.net.NioEndpoint$NioSocketWrapper.awaitReadLatch(NioEndpoint.java:1162)
at org.apache.tomcat.util.net.NioBlockingSelector.read(NioBlockingSelector.java:184)
at org.apache.tomcat.util.net.NioSelectorPool.read(NioSelectorPool.java:235)
at org.apache.tomcat.util.net.NioSelectorPool.read(NioSelectorPool.java:216)
at org.apache.tomcat.util.net.NioEndpoint$NioSocketWrapper.fillReadBuffer(NioEndpoint.java:1293)
at org.apache.tomcat.util.net.NioEndpoint$NioSocketWrapper.read(NioEndpoint.java:1235)
at org.apache.coyote.http11.Http11InputBuffer.fill(Http11InputBuffer.java:796)
at org.apache.coyote.http11.Http11InputBuffer.access$300(Http11InputBuffer.java:42)
at org.apache.coyote.http11.Http11InputBuffer$SocketInputBuffer.doRead(Http11InputBuffer.java:1175)
at org.apache.coyote.http11.filters.IdentityInputFilter.doRead(IdentityInputFilter.java:140)
at org.apache.coyote.http11.Http11InputBuffer.doRead(Http11InputBuffer.java:263)
at org.apache.coyote.Request.doRead(Request.java:585)
at org.apache.catalina.connector.InputBuffer.realReadBytes(InputBuffer.java:344)
at org.apache.catalina.connector.InputBuffer.checkByteBufferEof(InputBuffer.java:663)
at org.apache.catalina.connector.InputBuffer.read(InputBuffer.java:370)
at org.apache.catalina.connector.CoyoteInputStream.read(CoyoteInputStream.java:183)
at java.io.FilterInputStream.read(FilterInputStream.java:133)
at org.apache.commons.fileupload.util.LimitedInputStream.read(LimitedInputStream.java:134)
at org.apache.commons.fileupload.MultipartStream$ItemInputStream.makeAvailable(MultipartStream.java:999)
at org.apache.commons.fileupload.MultipartStream$ItemInputStream.read(MultipartStream.java:903)
at java.io.FilterInputStream.read(FilterInputStream.java:107)
at org.apache.commons.fileupload.util.Streams.copy(Streams.java:100)
at org.apache.commons.fileupload.util.Streams.copy(Streams.java:70)
at org.apache.commons.fileupload.FileUploadBase.parseRequest(FileUploadBase.java:347)
at com.atlassian.plugins.rest.common.multipart.fileupload.CommonsFileUploadMultipartHandler.getForm(CommonsFileUploadMultipartHandler.java:72)
at com.atlassian.plugins.rest.common.multipart.jersey.MultipartFormMessageBodyReader.readFrom(MultipartFormMessageBodyReader.java:36)
at com.atlassian.plugins.rest.common.multipart.jersey.MultipartFormMessageBodyReader.readFrom(MultipartFormMessageBodyReader.java:25)
at com.sun.jersey.spi.container.ContainerRequest.getEntity(ContainerRequest.java:490)
at com.sun.jersey.spi.container.AdaptingContainerRequest.getEntity(AdaptingContainerRequest.java:236)
at com.atlassian.plugins.rest.common.multipart.jersey.MultipartFormDispatchProvider$1.getInjectableValues(MultipartFormDispatchProvider.java:57)
at com.atlassian.plugins.rest.common.interceptor.impl.DispatchProviderHelper$EntityParamInInvoker.getParams(DispatchProviderHelper.java:129)
at com.atlassian.plugins.rest.common.interceptor.impl.DispatchProviderHelper$ResponseOutInvoker._dispatch(DispatchProviderHelper.java:178)
at com.sun.jersey.server.impl.model.method.dispatch.ResourceJavaMethodDispatcher.dispatch(ResourceJavaMethodDispatcher.java:75)
at com.sun.jersey.server.impl.uri.rules.HttpMethodRule.accept(HttpMethodRule.java:302)
at com.sun.jersey.server.impl.uri.rules.ResourceClassRule.accept(ResourceClassRule.java:108)
at com.sun.jersey.server.impl.uri.rules.RightHandPathRule.accept(RightHandPathRule.java:147)
at com.sun.jersey.server.impl.uri.rules.RootResourceClassesRule.accept(RootResourceClassesRule.java:84)
at com.sun.jersey.server.impl.application.WebApplicationImpl._handleRequest(WebApplicationImpl.java:1542)
at com.sun.jersey.server.impl.application.WebApplicationImpl._handleRequest(WebApplicationImpl.java:1473)
at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1419)
at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1409)
at com.sun.jersey.spi.container.servlet.WebComponent.service(WebComponent.java:409)
at com.sun.jersey.spi.container.servlet.ServletContainer.service(ServletContainer.java:558)
at com.atlassian.plugins.rest.module.RestDelegatingServletFilter$JerseyOsgiServletContainer.doFilter(RestDelegatingServletFilter.java:160)
at com.sun.jersey.spi.container.servlet.ServletContainer.doFilter(ServletContainer.java:829)
at com.atlassian.plugins.rest.module.RestDelegatingServletFilter.doFilter(RestDelegatingServletFilter.java:70)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:62)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:37)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:55)
at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:43)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.lambda$doFilter$0(DelegatingPluginFilter.java:57)
at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$$Lambda$1488/1551615290.doFilter(Unknown Source)
at com.atlassian.plugins.rest.module.servlet.RestServletUtilsUpdaterFilter.doFilterInternal(RestServletUtilsUpdaterFilter.java:23)
at com.atlassian.plugins.rest.module.servlet.RestServletUtilsUpdaterFilter.doFilter(RestServletUtilsUpdaterFilter.java:35)
at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:24)
at com.atlassian.mywork.client.filter.ServingRequestsFilter.doFilter(ServingRequestsFilter.java:32)
at com.atlassian.jira.plugin.mobile.web.filter.MobileAppRequestFilter.doFilter(MobileAppRequestFilter.java:59)
at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:32)
at com.atlassian.jira.plugin.mobile.login.MobileLoginSuccessFilter.doFilter(MobileLoginSuccessFilter.java:54)
at com.atlassian.diagnostics.internal.platform.monitor.http.HttpRequestMonitoringFilter.doFilter(HttpRequestMonitoringFilter.java:55)
at com.atlassian.analytics.client.filter.UniversalAnalyticsFilter.doFilter(UniversalAnalyticsFilter.java:75)
at com.atlassian.analytics.client.filter.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:33)
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:21)
at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFixupFilter.doFilter(PrettyUrlsSiteMeshFixupFilter.java:32)
at com.atlassian.prettyurls.filter.PrettyUrlsDispatcherFilter.doFilter(PrettyUrlsDispatcherFilter.java:55)
at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:80)
at com.atlassian.prettyurls.filter.PrettyUrlsMatcherFilter.doFilter(PrettyUrlsMatcherFilter.java:51)
at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:35)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at com.atlassian.jira.web.filters.MobileAppRequestFilter.doFilter(MobileAppRequestFilter.java:36)
at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.executeRequest(AccessLogFilter.java:93)
at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.doFilter(AccessLogFilter.java:79)
at com.atlassian.jira.web.filters.pagebuilder.PageBuilderFilter.doFilter(PageBuilderFilter.java:81)
at com.atlassian.jira.web.filters.CommittedResponseHtmlErrorRecoveryFilter.doFilter(CommittedResponseHtmlErrorRecoveryFilter.java:55)
at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:39)
at com.atlassian.ratelimiting.internal.filter.RateLimitFilter.doFilter(RateLimitFilter.java:73)
at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:56)
at com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter.doFilter(XsrfTokenAdditionRequestFilter.java:46)
at com.atlassian.jira.web.filters.MauEventFilter.doFilter(MauEventFilter.java:49)
at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:66)
at com.atlassian.jira.security.JiraSecurityFilter$$Lambda$211/477828823.doFilter(Unknown Source)
at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:242)
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:64)
at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:94)
at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:148)
at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:77)
at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:67)
at com.atlassian.plugins.rest.module.servlet.RestSeraphFilter.doFilter(RestSeraphFilter.java:38)
at com.atlassian.pats.web.filter.TokenBasedAuthenticationFilter.doFilter(TokenBasedAuthenticationFilter.java:83)
at com.atlassian.jira.web.filters.johnson.JiraJohnson503Filter.doFilter(JiraJohnson503Filter.java:79)
at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:394)
at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30)
at com.atlassian.plugins.authentication.impl.basicauth.filter.DisableBasicAuthFilter.doFilter(DisableBasicAuthFilter.java:70)
at com.atlassian.analytics.client.filter.JiraAnalyticsFilter.doFilter(JiraAnalyticsFilter.java:30)
at com.atlassian.ratelimiting.internal.filter.RateLimitPreAuthFilter.doFilter(RateLimitPreAuthFilter.java:71)
at com.atlassian.web.servlet.plugin.LocationCleanerFilter.doFilter(LocationCleanerFilter.java:36)
at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:74)
at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:31)
at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:39)
at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:39)
at com.atlassian.jira.web.filters.MultipartBoundaryCheckFilter.doFilter(MultipartBoundaryCheckFilter.java:36)
at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(MetricsCollectorFilter.java:25)
at com.atlassian.jira.web.filters.JiraFirstFilter.doFilter(JiraFirstFilter.java:61)
at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:121)
at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:92)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:544)
at org.apache.catalina.valves.StuckThreadDetectionValve.invoke(StuckThreadDetectionValve.java:206)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:143)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:690)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:616)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:831)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1634)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
ydwang@gxatek.com January 4, 2022
catalina.out  错误日志
java.lang.Throwable
04-Jan-2022 15:24:55.278 WARNING [ContainerBackgroundProcessor[StandardEngine[Catalina]]] org.apache.catalina.valves.StuckThreadDetectionValve.notifyStuckThreadDetected Thread [http-nio-8080-exec-209] (id=[895]) has been active for [121,126] milliseconds (since [1/4/22 3:22 PM]) to serve the same request for [http://223.244.84.116:8080/rest/api/2/issue/A58A88GOS2-3941/attachments] and may be stuck (configured threshold for this StuckThreadDetectionValve is [120] seconds). There is/are [93] thread(s) in total that are monitored by this Valve and may be stuck.
java.lang.Throwable
Catalina.out 错误日志
java.lang.Throwable
SERVER
VERSION
v8.16.1
