Jira 8.13 causes GUI issues with dropdown menus in Customer Portals
Mark Milford
Jira 8.13 causes GUI issues with dropdown menus in Customer Portals. With all browsers, the dropdowns don't appear / appear incorrectly. Is this a known issue? We have yet to try  SAFE MODE to iron out possible plugin issues.
We also updated Jira Service Desk from 4.0.2 to 4.13.0
Mark Milford
For those who stumble upon this, it's being corrected by the vendor here :
https://productsupport.adaptavist.com/browse/SRJIRA-4829
Related to Scriptrunner plugin
Dirk Ronsmans
Hi @Mark Milford ,
Do you use any specific add-ons to fill these dropdown or perhaps behaviours?
if they don't load correctly you can always open a developer console on your browser (e.g. F12 on Chrome) and see if they throw any errors.
A screenshot is also helpfull so we can better analyze the problem!
Mark Milford
HI @Dirk Ronsmans
No, nothing crazy there. We are only running a 6 or so plugins in Jira (Scriptrunner, Automation, etc) but do nothing of the sort with the customer portal. We opened a ticket with Atlassian and included screenshots.
Dirk Ronsmans
Well i've had a similar issue with Scriptrunner on that version. I suggest disabling that for a moment and seeting if it helps.
Even on projects where there were no behaviours defined the check broke the loading of the screens.
Like Mark Milford likes this
Mark Milford
Interesting! Were you able to isolate to scriptrunner via disabling it / running in safe mode?
Mark Milford
Dirk - you were correct! Disabled Scriptrunner, and the drop down works again! Shoot, we are running the latest version (6.12.0). Investigating now....
Dirk Ronsmans
remember you cannot downgrade below 6.0.0 as it has breaking changes below that version.
I suggest the developer console and opening a ticket with them.. for me it showed something like:
Unhandled promise rejection TypeError object doesn't support property or method 'finally'
Stephen Garber
October 30, 2020
I don't see this as a reported issue on jira.atlassian.com.
Have you updated service desk after you moved to 8.13?
Are there any issues appearing in the application logs?
Mark Milford
Thanks for the reply!
We updated Jira Service desk from 4.0.2 to 4.13.0 at the same time.
Stephen Garber
October 30, 2020
This is definitely abnormal behaviour. Review the logs for any hints about what could be happening and engage atlassian's support team to see if they can help provide a resolution.
https://support.atlassian.com/contact/
Mark Milford
Thanks Stephen - we opened a ticket and threw in some screenshots.
