Jira Admin External System Import not updating Resolution Date correctly
Robb Robins March 6, 2023
Hello!
I am attempting to use External System Import to update the Resolution Date for one issue in Jira (cloud).
Steps:
  1. Search for the issue in Advanced Search (issue = XXX-72)
  2. Export to Google Sheets
  3. Clear all columns except for KEY, SUMMARY, RESOLUTION, RESOLVED
  4. Download as CSV
  5. Open External Importer (I am a Jira Admin)
  6. Choose file (.csv) and select Next
  7. Select project, adjust date/time format to match the CSV, and select Next
  8. Map KEY -> ISSUEKEY, SUMMARY -> SUMMARY, RESOLUTION -> RESOLUTION, RESOLVED -> DATE RESOLVED, select "Map field value" for each and select Next
  9. Manually confirm and select Begin Import
  10. Success message "None issues and projects imported." This is the message I get when the import is successful
Here's where the issue is: in the CSV I had set the Resolved Date for 5/11/2022, but the issue in Jira now says 1/11/2022. This is different than the date that was listed before the import (3/4/2023), but not the date I put in the CSV.
Any thoughts as to what is going on?
Ashish Bijlwan
March 6, 2023
Hi @Robb Robins
Kindly refer https://docs.oracle.com/javase/1.5.0/docs/api/java/text/SimpleDateFormat.html for the Date Format for External System Import
Thank you,
Ashish
Hi Ashish,
Thanks for the reply! My dates are formatted correctly, to my knowledge. Do you see something off?
Ashish Bijlwan
March 6, 2023
Hi @Robb Robins
Please check and change the format to d-m-yyyy (5-11-2022) instead of dd-MM-yyyy.
Follow the pattern as given examples
If date format is 2-1-2022use d-m-yyyy
else if 2-01-2022use d-mm-yyyy
else 02-01-2022 use dd-mm-yyyy
Following the pattern you show above results in the same result.
The issue still has 01/11/2022 as the resolved date. The CSV I am importing has 05/11/2022 as the value.
Kelly Arrey
March 7, 2023
@Robb Robins
tl;dr
  • dd/mm/yyyy is interpreted as Day/Minute/Year
  • if you mean Day/Month/Year, use dd/MM/yyyy.
Robb Robins March 7, 2023
🤦‍♂️ You solved it, @Kelly Arrey
Thank you so much!
Like Kelly Arrey likes this
Kelly Arrey
March 7, 2023
Glad that helped!  This has bitten a lot of people recently (don't ask me how I found out about it :-))
