Hello!
I am attempting to use External System Import to update the Resolution Date for one issue in Jira (cloud).
Steps:
Here's where the issue is: in the CSV I had set the Resolved Date for 5/11/2022, but the issue in Jira now says 1/11/2022. This is different than the date that was listed before the import (3/4/2023), but not the date I put in the CSV.
Any thoughts as to what is going on?
Hi @Robb Robins
Kindly refer https://docs.oracle.com/javase/1.5.0/docs/api/java/text/SimpleDateFormat.html for the Date Format for External System Import
Thank you,
Ashish
Hi Ashish,
Thanks for the reply! My dates are formatted correctly, to my knowledge. Do you see something off?
Hi @Robb Robins
Please check and change the format to d-m-yyyy (5-11-2022) instead of dd-MM-yyyy.
Follow the pattern as given examples
If date format is 2-1-2022use d-m-yyyy
else if 2-01-2022use d-mm-yyyy
else 02-01-2022 use dd-mm-yyyy
Following the pattern you show above results in the same result.
The issue still has 01/11/2022 as the resolved date. The CSV I am importing has 05/11/2022 as the value.
tl;dr
Glad that helped! This has bitten a lot of people recently (don't ask me how I found out about it :-))
