Jira Automation Add a component when any of a specified list of labels are added
Larkin Rogers
Hello, when a user adds a label from a specific set of labels, either at creation or when editing, then I want a specific component to be added. I dont want to remove any existing components.
I added how I have the automation rule set up, but it is not even registering on the log when I change a label.  ThanksJira Rule.JPG
2 accepted
Trudy Claspill
For the issues where you are testing this, do those issues have any Component value already or is the field empty?
Your condition on the Component field will apply only if the Component field has at least one value. If you want it to apply to issues that also have no Component values at all you will need the JQL to be this:
component !=CS or component is empty
Larkin Rogers
the component field is sometimes empty and sometimes not.  Ill updated the search to look like this now:
But I am getting this error: SUN-5232 (Field 'components' cannot appear in both 'fields' and 'update')
Bill Sheboy
April 23, 2021
That error is because you have both selected the field above and used it in JSON below.  Please try to deselected in the list above, or use the method I noted to add new values after copying the existing ones (so you would remove the JSON.)
Like Trudy Claspill likes this
Larkin Rogers
 I deleted the action out and rebuilt it and it now works.  Thanks
Larkin Rogers
Thanks Trudy, really helpful, got it working with you and Bill's inputs. I really appreciate you all
Like Bill Sheboy likes this
Bill Sheboy
April 23, 2021
Hi @Larkin Rogers
Have you tried the method where you first copy from the issue and then add the new value?  Please look here for details:
https://support.atlassian.com/jira-software-cloud/docs/edit-issue-fields/#Editissuefields-Addvaluestomulti-selectfields
Best regards,
Larkin Rogers
Bill, that was it, thanks.
