Jira Automation - Create Slack Channel
Michael Morrison
July 24, 2022
Our team creates a dedicated slack channel for each jira issue in our sprint.
I'd like to automatically create a slack channel utilizing Jira Automation or one of the integrated plugins but i'm not finding any way to do this.
Ideally it would be when the issue moves from To Do to In Progress or when it becomes part of a sprint.  I know I can manually link a jira issue with a specific slack channel, but was hoping this could be automated.  Let me know if you have any suggestions.
4 votes
Emel Doğrusöz
Michael, any progress with this?
You can use Actioner's Jira app for this:
https://marketplace.atlassian.com/apps/1230509/jira-for-slack-by-actioner?tab=overview&hosting=cloud
Let me know if you need any help.
Emel @ Actioner
TheWookieEng
November 28, 2023
Check out NextUp - they have Jira Servicedesk + app that can do this with just a push of a button from the Jira case.
carlosughini
Hi Michael,
Welcome to the community!
Unfortunately, at the moment it is not possible to create a channel in slack, only to send a notification message.
You can double check this by checking the documentations below:
Please check the documentation above to understand more about how to send notifications to slack, but unfortunately creating a slack channel is not supported at the moment.
Carlos
Tim Padgett
Has there been any progress on this?  i.e. can jira automations now create slack channels?
Like Marc likes this
