Jira Automation - Edit issue multi user picker field
Arthur S
I am trying to use the Jira automation to edit a multi user picker field. What I am trying to achieve is, when people "approve" the ticket using the transition, I have an automation which add the user to my multi user picker cf "approved by" and it remove him from "approvers".
I am using the following but can't make it work properly :
and I have the following code :
"update": {
"approved by": [{
"set": {{initiator.accountId.asJsonObject("id")}}
can you please help me ?
d.kirsching
Hi @Arthur S
Maybe the smart value {{approval.approver}} is your solution.
Regards
Arthur S
Hi @d.kirsching thank you, I found the right solution, I tried your proposal and it did not add the user to the list. But based on what you proposer, I tried with {{initiator.accountId}} instead in the "Request participants" field, and it adds me my user.
Hi now need to find how to remove the user from the "approvers" field. Any idea ? I have the following code :
"update": {
"approvers": [{
"remove": {{initiator.accountId}}
Thank you,
Arthur
d.kirsching
Hi @Arthur S
Please find below the right code.
All informations for Advanced Fields Editing can be found here :
https://support.atlassian.com/cloud-automation/docs/advanced-field-editing-using-json/#Referencing-issue-fields
"update": {
"approvers" : [
"remove": {
"id":"{{initiator.accountId}}"
Regards
Like Richard Scholtes likes this
Arthur S
I also tried it earlier but this is not working. It shows a success but it's not removing the user from my field.
d.kirsching
For me it'w working with the trigger Approval completed
Arthur S
I'm on Jira software and not Jira service management, so I don't have the "Approval completed". For me it should work on the Edit Issue but I don't know why, it's not.
Hana
March 10, 2022
In case you didn't find your answer... this one worked for me:
  "update": {
     "Approvers" : [
         "remove": {
            "name":"{{initiator}}"
Like # people like this
Arthur S
I tested it and that works.
Thank you
Yogesh Mude April 27, 2023
Hello @d.kirsching ,
I want to remove the initiator (who triggered it) from the Approvers field but with the above code, it's removing all the other users, not the initiator.
Any assistance will be appreciated.
Thank you in advance.
Harsh
November 14, 2023
I am also facing the same issue, that I cannot either add or remove a user from multi user custom field.
I am using
Remove:
"update": {
"customfield_12345": [{
"remove": {"id":"{{1585625}}"}
Add:
"update": {
Is there something wrong in above, am I missing something?
Thanks!
