Jira Automation: How to populate parent custom field value to sub-tasks?
Iana April 27, 2021
I am trying to build algorithm which will auto populate some certain custom field from parent to child issue (from Epic to Story and to sub-tasks).
Please can you advice what rules have to be applied?
Thank you,
Iana
Kevin Johnson
Iana April 28, 2021
Hi Kevin,
Thank you for your help.
Anyway, in my case it is still not working :(
When issue created or edited I need to populate a custom field value from parent to sub-task (existed or newly created) and from Epic to Story.
I've added a screenshot bellow, please can you check it and advice what is wrong?
Many thanks!
Like Kevin Johnson likes this
Kevin Johnson
Hey @Iana ,
Happy to tell you that after few attempts, I was able to figure out a solution. Attaching the pictures below for your reference. Please replicate the same to "Copy custom field value from an Epic to Story when a Stroy is created". Hope it helps.
Like # people like this
Iana May 14, 2021
Thank you
Kevin Johnson
@Iana Please accept the answer if it works out for you, so it can be useful for others too.
Kevin.
