Hi!
I am trying to use JIRA Automation to create sub tasks in a parent issue, as a part of onboarding. This means the parent issue will be created by somebody, and a custom field - Manager - where the JIRA user responsible for the new employee will be selected.
So, I can create the sub task when the parent issue is transitioned, but I am struggling to set the Manager as an assignee for the sub task.
I am trying to add this as a JSON script under More options / Additional fieldsat the bottom of the Sub Task feature, but the rule fails to add assignee. I have tried with various variations of triggerissue, parentissue, .key, .accountId and so on.
"fields": {
"assignee": { "id": "{{triggerissue.customfield.10091.accountId}}" }
Any help is greatly appreciated. Thanks!
I notice there is a typo in your JSON expression:
{{triggerissue.customfield.10091.accountId}} should be
{{triggerissue.customfield_10091.accountId}}
@[deleted]
Hi! I'm looking to do something similar but can't get this solution to work for me. I have issue type "Article" with a custom people field for "Manager" (custom field ID 11134). When creating an issue of this type, I will fill the Manager field in with either "Aaron" or "Bobby".
I want to automatically assign the "Approve" task to Manager each time it is created, depending on who the Manager is, either Aaron or Bobby.
Here are a few things I have tried:
With these, the Approve subtask is created, but the Manager (Aaron or Bobby) is not added as the assignee (blank assignee field) —
With this, the Approve subtask is not created and it runs with an error —
If you could advise, I would appreciate it so much! Thanks!
Hi @Emma Hecht
First thing, you seem to be trying to set the assignee in two places, with the field and in the advanced edit with JSON. Try clearing out the advanced edit.
Next, would you please post images of your complete rule and the audit log showing details of a rule run? Those may provide context for what is happening. Thanks!
And just to confirm, is this for a team-managed (TMP) or a company-managed project (CMP)? I am guessing TMP as you note have a People field type.
@Bill Sheboy Hi! Thanks so much for your response!
On the Assignee field and Additional fields — I ran each of those tests separately (so if I had something in the Assignee field, I didn't have any JSON in the Additional fields and vice versa)
Images of the rule —
Audit log (the whole log is configuration change > some errors, with some errors always being this same JSON message) —
Last, yes this is a team managed project, which allows me to create the custom person fields like below for issues —
This is curious...I tried your scenario and it worked for me...
Rules sometimes get "glitched" when adding/removing the advanced edit with JSON stuff. Let's try this: disable this rule, and recreate it from scratch and retest.
Follow-up question — should the custom field smart key work for sending emails? I'm trying to use it in the "to" field for an email notification, but I'm getting an error:
To field:
Issue path:
Audit log:
Sadly, not yet...For some reason the People-type field's design in team-managed projects does not support the user attributes like email address.
Here is the suggestion to add that information, which you may watch/vote for to see progress: https://jira.atlassian.com/browse/JSWCLOUD-22200
The work-around depend on usage...
Interested in learning how to implement the REST API solution! (So sorry, I don't have a strong background in coding or Jira). Can't find much on how to do this in Jira Is there an article I'm missing or would you be able to post a screenshot or the code?
Context: When I'm moving a certain subtask from "upcoming" to "done" I want to send an email to another user (not the assignee or one of the Jira-defined person fields, like reporter).
Thank you!
Well done!
For future reference if you need to call the REST API for things automation rules do not support directly, please see this how-to article:
With your use case of getting the email address from the account Id, the method to call would be this:
yourJiraUrl/rest/api/2/user?accountId=theDesiredUserAccountId
Refer to the image below.
In field #1 choose Assignee.
In field #2 choose Copy From Parent.
Thank you @Trudy Claspill
This could have been a solution, but in this particular case the assignee for the sub tasks would not always be the same as assignee for the parent issue.
