Hi everyone,
I can't seem to figure out on how best to build the Jira Automation for my use case so I would really appreciate any guidance.
Based on the info above, here are the steps in what I would like Jira Automation to do:
Please see below the list of issues (under Epic Alpha) that have been estimated and are ready for approval
- Story 1 Issue Summary --> <Original Estimate Value>
- Story 2 Issue Summary --> <Original Estimate Value>
- Story 3 Issue Summary --> <Original Estimate Value>
- Story 4 Issue Summary --> <Original Estimate Value>
- Story 5 Issue Summary --> <Original Estimate Value>
The total estimate for all the estimated issues is = <Total Sum of all the Original Estimate Values for Stories 1-5>
Here's what I have built so far. I'm not sure if I'm going about this the right way, or if there's a better way to achieve what I'm looking for. I basically got stuck half way, so looking for guidance from this great community.
Thank you
A question and a suggestion for your rule...
Question:
What is the purpose of using the transition back to the same status as the trigger? For example, is another rule or activity causing this "self-transition", or could a manually-triggered rule be more helpful?
Suggestion:
By branching to all issues in the epic and then testing each one with conditions, the rule is looking at more issues than necessary AND will add a comment for each issue.
As an alternative, consider removing the branch/conditions and creating a JQL statement to find the issues in the epic meeting your condition. Then use that JQL with a Lookup Issues action. That will allow creating a single comment using this syntax:
Please see below the list of issues (under Epic {{triggerIssue.key}}) that have been estimated and are ready for approval
{{#lookupIssues}}
* {{summary}} --> {{Original estimate|0}}
The total estimate for all the estimated issues is = {{lookupIssues.Original estimate.sum|0}}
Thanks Bill, I think you're spot on with your suggestion on foregoing the branch/condition and stick to JQL/Lookup Issues Action!
I'm assuming the Manual Trigger would be on the Epic Issue Type, yes?
Can you please let me know what JQL statement I could use that runs and checks for all story level issues within an Epic (when it is triggered manually, for each Epic).
I would imagine a JQL statement with an actual issue key as a parameter in the automation rule would be redundant since the rule would need to look for the Epic in question upon the manual trigger.
Thanks a bunch for your help!
Yes, you would manually trigger the rule on the epic...or perhaps use another trigger if that makes sense.
For the JQL in the Lookup Issues action, perhaps try this:
project = myProjectName AND "Epic Link" = {{triggerIssue.key}} AND Labels = Backbone-Sync AND "Original Estimate" > 0 AND customfield_10200 = "Yes"
I recommend trying the query stand-alone with advanced issue search and an example Epic first, then try it in the rule.
Thanks Bill — Unfortunately that JQL is not working in the Lookup Issues Action. I tried it in the advanced issue search as well as validating the query in the automation rule. No dice.
Your single comment syntax was very useful though, and I've been able to setup the automation by having me send an email with the list of issues I'm looking for, instead of having that same email content be posted as a comment on the Epic (Parent Issue) which is what I had originally hoped for.
Appreciate your time and effort!
My mistake, as you need to use originalEstimate and not "Original Estimate" in the JQL.
Also...Is this a company-managed (CMP) or a team-managed project (TMP)? CMP ones use "Epic Link" and TMP use "parent" to link epics to children.
Once you change those things, please try your JQL in a standalone query with an example Epic. Once that works, it should also work with the lookup.
It worked! Thanks so much, Bill!
There is one more thing that I'm hoping you would be kind enough to shed some light on, seeing as you're quite the automation for Jira expert ;)
I'm trying to list these issues in a table format
This is the my automation rule post adjustments:
project = "ion8 Backbone Project" AND "Epic Link" = {{triggerIssue.key}} AND status = "Estimate Review" AND originalestimate > 0h AND "Estimate Ready for Approval[Radio Buttons]" = Yes AND labels = Backbone-Sync
Hi Team,
Please review the list of issues (under Epic {{triggerIssue.key}}) that have been estimated and are ready for approval.
| *KEY* | *SUMMARY* | *ESTIMATE (Hours)* |
| {{lookupIssues.key}} | {{lookupIssues.summary}} | {{#=}}{{lookupIssues.Original estimate|0}} / 3600{{/}} |
*The total hours for all issues estimated under Epic {{triggerIssue.key}}* = {color:teal}*{{#=}}{{lookupIssues.Original estimate.sum|0}}/3600{{/}}*{color} *hours*
^as you can see, I'm trying to display the list of issues, their key, summary and estimate in a table format.
The output is this based on the automation rule above:
The above is correct; It is giving me only Blue Story 1 details because out of the 3 child issues, only the child issue Blue Story 1 is in the status "Estimate Review"
However, when I update the status for Blue Story 2 and Blue Story 3 to "Estimate Review" (like seen below)
And now when I try to run the rule, it gives me an error
This is the error message from the audit log:
What am I doing wrong? Any ideas or suggestions on how I might fix this. I feel like we are so incredibly close, so THANK YOU for all the wonderful suggestions and help @Bill Sheboy !
Best,
P.S this is the automation rule. I figured I'd post a screenshot of it just in case :)
I believe you were missing the iterator to walk the issues in the lookup. You can handle that by always assuming you have multiple issues to display by using the iterator like this:
{{#lookupIssues}}
| {{key}} | {{summary}} | {{#=}}{{Original estimate|0}} / 3600{{/}} |
That did the trick!
Thanks again for all the help, Bill!
