Dear Community,
I've thought it was an easy one but actually I'm being struggling:
I would like to create a Jira Automation Rule such that when a field goes out from a specific value (which is Blocker), a comment is added to the ticket.
See please attached my current rule flow and could you please let me know if there is a condition such that the comment is added only when this field chnages its value from "Blocker" to any other of the 4 values? (Blocker/Critical/Major/Minor/Normal).
As it is now, a comment is added also when this field changes for example from Minor to Major (which I don't want).
Thanks in advance, Vincenzo.
Thank You @Hans Polder _Devoteam_ very much.
It works indeed, and no need even of the first "If": that's very smart.
Kind Regards, Vincenzo.
@vincenzo.spatafora Happy to hear! Could you help me by clicking the 'Accept answer' button next to my reply? This will mark the question as Resolved.
The IF at the start could maybe be helpful, if for some reason a ticket is changed from Blocker to Blocker, but I'm assuming the chances of that are low (and maybe not technically possible). I leave it up to you to keep it in or out :)
