Ok, I'm hoping my questions are getting better.
Any ideas would be much appreciated.
I've been developing my rule to do one of two things; either move the ticket to On Hold IF there is a STAT CSR Listed AND there is no Approved BitBucket Pull Request, or create a sub task to ensure the STAT CSR is ready for CAB.
So, here's the layout:
WHEN Issued Transitioned from: "Pre-Prod Testing" or "Team Approved"
to: "Release Candidate"
- IF CSR Number is not empty
- IF matches {{pullRequest.state}} = Approved
Create Sub Task
- ELSE
Transition to ON HOLD
Send Email
So, I know that the Pull Request Smart Value is not available unless the Trigger is a PR Trigger. I also know that the Valid Values for {{pullRequest.state}} are Open, Declined and Merged.
I've also played around with the On Hold Notification to try and pull useful values to no avail. This is what I have for the notification right now:
Subject:
Issue {{issue.key}} / {{issue.customfield_10034}}- Immediate Review Required! Pull Request not APPROVED:
Content:
{{issue.fields.summary}} - {{issue.fields.updated}}
{{project.key}} - {{project.name}}
{{pullRequest.state}} - {{pullRequest.title}} - {{pullRequest.url}}
{{issue.Development}}
Hi @jh074626
There is an open suggestion to add a trigger for PR Approved, which you may watch / vote for to see progress: https://jira.atlassian.com/browse/JRACLOUD-81389
For pipeline scenarios where the automation rule triggers / actions do not provide help, you could try using the Send Web Request action to call the REST API endpoints for your source control tool.
Here is a how-to article for calling a REST API from an automation rule: https://community.atlassian.com/t5/Jira-articles/Automation-for-Jira-Send-web-request-using-Jira-REST-API/ba-p/1443828
Thanks, Bill
Wish we were using pipelines. I think we could avoid a number of issues if we were. Still, an API call may well be the way.
