HI all, Iam using jira automation over software project (data center version) to copy some filed from issue type I create to story linked to this issue type when I create story
but the problem when I create the automation rule it execute the action over the issue type I create not the story and they mention if i want to execute over the stroy i have to do below
Rule executes when an issue is linked to another issue. {{issue}} will always refer to the source issue, so if ISSUE-A is blocked by ISSUE-B, this rule will execute on ISSUE-B. To access ISSUE-A, use {{destinationIssue}}, and to access the link type, use {{linkType}} (e.g. {{linkType}}='Duplicate').
but I don't know where I have to mention this.
screenshot below.
I would like to thank you so much for your efforts and replies but unfortunately all smart variable didn't work with me at all but finally I found another solution and it work with me as below
You would typically use these Smartvalues in the Edit, etc ... actions where you can set a value as in this example:
Jeroen
this will not work for the required issue it still update the source issue can you please test it
below is my configuration by be Iam mistaken
Depending on the type of your field, the syntax you are using for Smartvalue of Customfield is not correct. Should look like this:
{{issue.customfield_10913}}If the update occurs on the wrong issue have a look at the difference between:
{{issue.customfield_10913}}AND
{{destinationIssue.customfield_10913}}
Depending on the type of custom field you might need to still add something to get the actual value. Have a look at this community post:
Jeroen
thanks a lot for your support it is high appreciated. but problem not solved yet my filed type is User Picker (single user) Filed name is (SA)
I try below but didn't work for both sides
{{issue.SA.value}}
{{destinationIssue.SA.value}}
Is there different options for this smart value ?
thanks alot
That would depend on what property of the user you would like.
Have a look at this page:
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-users/#User-properties
There you will see properties like emailAddress or displayName ... Maybe try one of those in the same way:
{{issue.SA.displayName}}
Jeroen
I try to copy OOB filed assigne and I try both below
{{destinationIssue.assignee}}
{{issue.assignee}}
but both action is performed in the source issue and i want to perform over destination issue :( :(
