Jira Automation error in rule
Valerie Blondel
Beginner here, sorry to ask.
Here is my request : whenever a change of value is detected in any of the fields "Direction Indice de risque total, Ressources humaines Indice de risque total... " I would like automation to re-calucate the sum, that should appear in field "Grand total des indices de risques".
Here is my automation so far :
I have this error :
Would any one be so kind to tell me what I am doing wrong ?
Thanks a lot,
Valérie
Trudy Claspill
Valerie Blondel
Hi Trudy,
Sorry for this !
I could not find this first post.
Still learning how to work with a community too.
Apologies for the inconvenience caused.
Aron Gombas _Midori_
Having a quick look, the first item in the expression starts with
{{issue
...but others start with
 {{lissue
There is an extra 'l'?! Is that intentional?
Valerie Blondel
Hi there,
Thanks for taking the time to answer me.
It was not intentionnal, and corrected in the meanwhile, but not working :-(.
Valérie
What does that mean "not working"? If you look for help, you may want to provide more details about how it behaves after the correction.
Valerie Blondel
Hi Aron,
Thanks for having a look.
Here is what I tried so far :
Corrected the string as follows ;
{{#=}} {{issue."Ressources humaines Indice de risque total".value}} + {{issue."Direction Indice de risque total".value}} + {{issue."IT Indice de risque total".value}} + {{issue."Gestion de projet Indice de risque total".value}} + {{issue."Commercial Indice de risque total".value}} + {{issue."Customer Solutions Indice de risque total".value}} + {{issue."Production Indice de risque total".value}} + {{issue."ENV et BAT Indice de risque total".value}} + {{issue."Logistique Indice de risque total".value}} + {{issue."Qualité Indice de risque total".value}} {{/}}
In another chat, someone also suggested to start with a shorter string.
I used {{#=}} {{issue."Direction Indice de risque total".value}} + {{issue."Logistique Indice de risque total".value}} {{/}}
Last thing I tried was to remove the " " :
Anything else I could try according to you?  Any help is more than welcome.
Thanks again,
Valérie
Trudy Claspill
Hello @Valerie Blondel
Are these custom fields all Number type fields?
For Number type fields this works for me
{{#=}}{{issue.<display name for field>}} + {{issue.<display name for field>}}{{/}}
I did not put quotes around the field names. I did not use the .value attribute.
Have you tried replacing the display name of the fields with their field ID; i.e. customfield_#####
