Jira Automation - how to create a rule to block creation issues with the identical summary
Jiri Pik
I am unable to get the conditions right.
The trigger is Issue created but am not sure how to get the condition "if the issue's summary is already present in the project" work.
Jack Brickey
you can't prevent the creation but you could create post-creation automation to close as duplicate. Automation works post-creation not pre-creation.
Jiri Pik
Thank you for the answer.
So the trigger is Issue created?
What is the condition? I have tried JQL with Project = XXX and it did not work.
Bill Sheboy
October 21, 2020
Hi @Jiri Pik
Yes, the trigger would be Issue Created...and due to potential timing issues you might want to add a re-fetch so the item is fully loaded.
Your JQL would check for any issues in your project which have the triggering issue's summary.
Perhaps something like this.
  • Trigger: Issue created
  • Action: re-fetch
  • Action: lookupIssues, with JQL like (note the ~ and the quotation marks)
    • project = myProject AND summary ~ "{{issue.summary}}"
  • Advanced compare condition:
    • First value is {{lookupIssues.size}}
    • Condition is Greater Than
    • Second value is 1
  • Action to close and comment on the duplicate, as @Jack Brickey noted
Best regards,
Like Jiri Pik likes this
Jiri Pik
@Bill Sheboy : THANK YOU
Like Bill Sheboy likes this
SERVER
