Jira Automation send slack alert 30 minutes before deployment
vv
Hello how would I go about setting up automation to send slack alert 30 minutes before deployment?
I have a status called Pre-build and custom field on issue with deployment time.
4 votes
Walter Buggenhout
Hi @vv and welcome to the Community!
I would use an automation rule with a scheduled trigger that runs e.g. every 5 minutes and runs a JQL filter that looks like this:
"deployment time" < 30m AND status = Pre-build
When this retrieves issues, it will execute actions on all issues returned by the filter. So you can send out your Slack notification and I would recommend to somehow flag an issue (e.g. by adding a custom field to it - e.g. notification sent - that you can update and use in your filter to avoid sending out notifications every five minutes after the first run.
Hope this helps!
vv
amazing thank you for the extra tip!
Like # people like this
FREE
