Jira Automation to remove Parent's label from child issue
Neville August 18, 2023
I already set the if conditional but I dont know how to set the edit action.
I try the additional fields.
"fields": {
"parent": {
"fields": {
"labels": []
But it wont work.
3 votes
Ste Wright
Hi @Neville
Can you clarify how the rule is meant to work?
  • Is there a specific label which is meant to be removed? If yes, how are you locating it?
  • Or, are you looking to NULL the labels field based on the parent?
  • Or something else?
Ste
Neville
August 18, 2023
Sorry for not provide sufficient information initially.
Scenario is
When task is change the status to done, it will remove the parent(epic) 's specific label (Pending_PRD_Development) and add a label (PRD_Done)
Ste Wright
Hi @Neville
You need to refer to the Epic via a Branch - so the rule is trigger from the child issue level, and actioned on the parent.
The rule might look something like this:
  • Trigger: Issue Transitioned
    • To Status = Done, Will Not Do, Duplicated
  • Conditions: Populate as required, based on your needs
  • Branch: Related Issues
    • Type = Epic (parent)
      • Branch-Action: Edit Issue
        • Field = Labels
          • Add = PRD_Done
          • Remove = Pending_PRD_Development
Let us know if this helps resolve your wider need - or if you need any additional instructions, let us know too!
Ste
Like # people like this
Works perfectly.
Thanks for your great help
Like Ste Wright likes this
