I am working on Change management type in Jira
My requirement is
1) When i select field "ABC" which is check box (YES/NO) mandatory .
Question , when i select YES, how the new text field should automatically display to update the text/number and when i select NO , no action is needed
You can use scriptrunner's Behaviour to hide/display 2nd field based on 1st field selection
below snippet may give you some idea
def field = getFieldByName("Field Name to hide/display")
def chkBox = getFieldByName('CheckBox Field Name')
def value = chkBox.getFormValue() as String
if(value == "Yes"){
field.setHidden(false) //Enabling field to enter value
else{
field.setHidden(true) //hide field if value is not Yes
BR,
Leo
Thanks, So i have to create a field first in jira 1) Field Name to hide/display 2)chekbox
Yeah, if you are not having already.
I meant ABC as a checkbox in my script --> for which you need to setup behavior with given code
field should automatically display to update the text/number ---> is the 2nd field should show up on (ABC == Yes)
As suggested above, Scriptrunner will work. You can also look at Live FIelds functions in Powerscripts.
But if you want to avoid scripting, you can look at Extension for Service Desk
Which will allow some dynamic screen without having to use scripting.
