Jira Code Block Macro?
Deleted user February 26, 2019
I know it's available in Confluence, but can we implement it in Jira?
Everything I find refers to Confluence.
Thanks!
Marty
February 26, 2019
Hi Tom,
I am not on the Jira team but I will try to help.
If your goal is to display code in various fields in Jira (like description, comments, etc.) then you can do so using the wiki-style markup.
https://jira.atlassian.com/secure/WikiRendererHelpAction.jspa?section=advanced
Eg.
{code:title=Bar.java|borderStyle=solid}
// Some comments here
public String getFoo()
    return foo;
{code}
If you can't use this markup then you (or your admin) may need to configure the correct renderer.
https://confluence.atlassian.com/adminjiraserver/configuring-renderers-938847270.html#Configuringrenderers-wikirenderer
I hope that helps!
Deleted user February 28, 2019
Thanks Martyn!
Is there anyway to add a language?
It would be nice to have PowerShell.
Like Marty likes this
Marty
February 28, 2019
Hi Tom,
that page I linked to mentions the following
"Makes a preformatted block of code with syntax highlighting. All the optional parameters of {panel} macro are valid for {code} too. The default language is Java but you can specify others too, including ActionScriptAdaAppleScriptbashCC#C++CSSErlangGoGroovyHaskellHTMLJavaScriptJSONLuaNyanObjcPerlPHPPythonRRubyScalaSQLSwiftVisualBasicXML and YAML."
I think the closest to PowerShell will be bash.
You could try
{code:bash}
{code}
I hope that helps!
Kenneth Lay
March 25, 2019
This is very confusing because in Confluence markup-style code blocks are used (backticks)
Mohamed Adel
February 26, 2019
Hi @Tom
What is the target of having this macro in jira ?!
Tom February 27, 2019
Hi
Ed
The code block is for simple syntax highlighting of code or text. Jira hasn't caught up to Confluence yet (even after many years), so there are no "advanced" features, like line numbering, theming, support for many languages, or showing it in a collapsible panel.
Basically, what it does for you is shows you the literal text (without having to escape Wiki markup) inside the panel, in a distinctive font, and supports some syntax highlighting for a few of the most popular development languages. You can also control the color of the main text, the background color of the panel, and give your panel a header with a title for easy reference. But nothing fancy beyond coloring a few keywords from the language you've specified.
