×Please help me recover my jira data center
You have to provide more information but these are what I would do at first.
- Check the logs or monitor the system to identify the errors or problems in the problematic node.
- Ensure that the other node is up to date with the latest data.
- Disable the problematic node that is not working properly.
- Update the cluster configuration to include the running node (modifying the Jira configuration files).
or you can seek assistance from the Atlassian support team for detailed guidance and specific troubleshooting steps tailored to your environment by providing the support zip file.
I hope it helps
Hi Thanks for your Reply,
but , i am new to jira administration, i dont know how data center works
but my manager asked me to remove 1 node which is "NO HEART BEAT"
& to add new Node to it within cluster page , please help me to find
-How Data Center works?
-How to create nodes?
-how to ADD/REmove nodes in Data Center?
-How to Create/install Jira using AWS Server as DATA Center
I see,
I think the best link to start finding answers to those questions is this.
Please have a look and digest.
