User set up dashboard with different data
for eg:- The Dashboard has data with the status as follows :-
1. New - 4
2. Ready for Triage - 6
3. Closed - 7
User has set up this with certain columns . when clicking on this link It should display in the same format how the dashboard creator has set up.
for eg:- when the user clicks new - it should display data in certain format how the creator has set up. Instead it is being displayed in different order
Dash board creator set up data - summary , status , assignee etc.
to the user it is being displayed - Status summary and some column's are not displayed as well.
But it is not being displayed in the same order and also some columns are not showing as well to the user whom it has been shared . Any solution to this
Hi @Akash
Can you share screenshots? Are you using a specific gadget?
I would check whether the users and the creators have access to both filters first. Also, ensure that the users have browse access to projects being used in the dashboards.
Fabian
Hi Fabian Lim ,
appreciate your quick response on this . The user is not using any specific gadget . With regards to the filter the creator himself set up those filters . Can you please let me know what kind of permission I need to give it to the users. I will check the browse access to project permission to the users.
Akash
