Hi all,
I have bug when I assigning a Insight Custom Field value to another custom field.
In a first Jira ticket, I assign a Insight object to a Insight custom field. Then I create via script another ticket, and populate my Insight Object to the other ticket.
Here, all seems good, but When I want to assign the value of this Insight Custom field to another custom field (not insight type), it returns me a set of values :
I use :
CustomField insightCustomField = ComponentAccessor.getCustomFieldManager().getCustomFieldObject(customFieldInsightID);
CustomField topopulate = ComponentAccessor.getCustomFieldManager().getCustomFieldObject(xxx);
issue.setCustomFieldValue(topopulate , insightCustomField)
In this case, the result in custom field is a comma separated list of values (and index 0 is not always the real value of insight custom field.
An idea ?
thanks in advance.
Regards
How do you want to filter it? By attribute (Object Name)?
Hi Gezim,
I found why, it's because I use findObjectsByIQLAndSchema function instead of findObjects.
Now, it's ok, except when the function returns only one value..
thanks
