Is it possible to have some projects integrated with GIT and others with SVN? Or is it one for all of Jira? I understand Fisheye or SVN plugin is required for SVN. I have some projects being managed in SVN and some in GIT so the goal (for now) is to try to support both in the same instance of Jira
Hi Steve,
I did some checking and as long as you have the requirements for SVN you can also integrate Git into the mix and have multiple repositories linked to JIRA.
This article shows you how to link JIRA to Github.
Branden
Hi Branden,
Thanks for the feedback. That's what I suspected but needed some additional advice.
Steve
No worries at all!
Yes, this is absolutely possible to have different JIRA projects using VCS repositories of different types (SVN, Git, Hg).
(You may also want to check the Commit Policy Plugin to improve the integration.)
