Jira Marketplace problems
Peter Jehle October 31, 2017
The lira server is behind a remote proxy. I have the followed problems:
- If I use the MarketPlace link under the user Icon the internal server IP is used.
- "Administration" -> "find new adding", the adding are shown but If I use the search no result is found
- "Administration" -> "Manage add-ons" -> "find new add-ons" the internal IP is used
Brant Schroeder
What is the base URL in JIRA set to?  Is it the internal IP?
Andy Heinzer
October 31, 2017
What Brant said:  I'd recommend making sure your base url in Jira is set to the same URL you are access Jira site on.  If the base URL is different than the site you are accessing, it is possible that the UPM in Jira would not be able to resolve the marketplace correctly.
