×Hello Jira-Support,
I want to migrate the Jira-Service-Desk from my company to another clean Jira.
To do this, I exported the complete Jira and delete all projects and users that do not belong to service-Desk. I did an export and now I imported this file into the new Jira.
The Import works perfect - but I have problems with the licenses. I configured the new Jira-Server-license at the beginning of the Import and now I am not able to add the service-desk. In the logs I cannot find any information - it only says "No plugins found to be installed"
Thank you for your help!
Greetings
Uwe Müller
Are you installing it from "manage applications"? What are the first lines in the log after you click "install"?
Yes I try to install the jira-server from the manage-applications menu.
The first log lines are:
/rest/plugins/1.0/installed-marketplace[c.a.plugin.loaders.ScanningPluginLoader] No plugins found to be installed
/rest/plugins/self-update/1.0/ [c.a.upm.pac.PacClientImpl] Update check request may take longer because of the number of add-ons
Ok, you'll need to look through the rest of the logs for warnings and errors.
What is showing in the "manage applications" though? Just "not installed"?
If it doesn't install when you ask it to, then it will be telling you why in the logs.
Maybe we should start from the beginning:
Can you tell me if the planned migration-way is a good one - or should we try it in another way.
Is it better to install service-desk-plugin before I restore the sytem from the zip.
Thank you.
