hello
we have a problem in our mobile app when we want to create an issue it shows an error - when i use my PC, create the issue for the same type it works.. whats the problem???
the error shown (Cant create the issue in this project. Try a different project) as the follow picture
@فادي I work in the Mobile App team. Would you mind send feedback through the app so we can get more info about you and the jira instance you are using. You can answer back in this thread when you've done it so we can track it.
Thanks @فادي , we already identified the issue and the fix is being rolled out as we speak.
The fix is in version 51 of android app.
