Jira Plan Inquiry
Travis Hill
I have a general question about Jira Plan. Are you able to hide / remove the numbering in the Work Item column so that it isnt in sequential order (1,2,3,4)
Alternatively, if thats not possible, can move a column from the field section in front of the work items? So for example Global Rank to be the first column in the plan (before Work item)?
Thanks in advance!
8 votes
John Funk
Hi Travis,
That's not the "work item column", it is just the row numbering like what you would have in a spreadsheet.
What is the actual issue you are trying to solve?
Travis Hill
Hi John thanks for reaching out. I am attempting to remove the row numbers because it is being conflated with rank, which is not the case.
Like John Funk likes this
John Funk
On the plan, you can drag the work items higher or lower.
Travis Hill
Thank you appreciate the feedback, that doesnt quite work for us in this situation but I am assuming, based on that, that the row numbers are not able to be hidden?
John Funk
You are welcome, and no, I am not aware of a way to hide those.
Travis Hill
Sounds good thank you!
ENTERPRISE
