×I have set up a Jira Plan with a filter that selects Epics and Stories based on a tag. All views display the expected data set, except the Summary page which has included and Epic & Stories which do not have the selected tag, but do have a due ate within the range set on the summary page.
This alters the status overview percentages because of the additional work outside of the plan.
Is this a known issue or have I missed some configuration within the plan
What's the JQL for the plan you are working with? What data sources are you using?
The data source is based on a Jira Project - using tags to define the data set. I didn't think you could access JQL for a plan
Sorry for the late reply, but you can use this page View and change the scope of work in your plan | Jira Cloud | Atlassian Support try using JQL to find the data you are looking for! @Andy
