Jira Portfolio New Expirience
felix.severa@reedexpo.at August 11, 2019
Hi, why does Jira Portfolio New Expirience only fill the remainig estimate and not the original estimate ?
In this case, i dont' see the correct time in my Jira Backlog ?
Thanks Felix
Manuel Bastardo Castellano
August 11, 2019
No problem, i found this but i m not current using Portfolio, check if you can back to classic view and get it..
Currently the "Original Estimate" field is not part of the new Experience feature set, if the estimate is critical to your process switch back to the classic view and recalculate the plan to get the field back.
Also, we have the following feature request to add this back to the New experiance, please make sure to add your vote to help us track interest and if you have any additional feedback on the feature please make sure to add a comment as well noting the impact for your use case:
August 11, 2019
Hello felix.severa@reedexpo.at maybe should use classic projects, NG projects are not design to work with Portfolio
Check this https://confluence.atlassian.com/jiraportfoliocloud/portfolio-for-jira-next-gen-support-968663298.html
Regards
may be i explained it wrong, we use the new view in portfolio.
I went throught the link, yes we don't use nex gen projects. sorry
