Each of my development teams works from separate jira project. Is there a way I can associate a team in advanced roadmaps with a jira project?
I want the roadmaps to show progress of the project sprints
Absolutely! Advanced Roadmaps is great for doing just that.
You can set up a plan and select the specific projects/boards/filters that you want to see in it, and then configure exactly what you want to see. You can even save different views to switch around quickly to explore the progress and blockers at different levels.
If you set up a team for each project you can specify their expected velocity in sprint points and see where you have excess or not enough resource in place.
https://confluence.atlassian.com/advancedroadmapscloud/getting-started-998650919.html
@Stuart Capel - London Can I associate the team in adv roadmaps with the Jira project? For example, Catalog team is the jira project CAT?
Yes - you can:
The associated issue source can be a project - Advanced Roadmaps will help you schedule your work based on the predicted velocity in story points
