I am using the default Jira name for the "Priority" field. See attached image.
I know how to change the name in the admin console, but it applies it globally. Is there a way to change the label name by project?
Example:
Global Name (currently):
P0 - Blocker
P1 - Critical
Desired:
Project 1:
P0 - Blocker
P1 - Critical
Project 2:
P0 - Immediately
P1 - Next Sprint
The reason for this, we have users of Jira who are not tech savvy and it helps them understand how to assign a priority to something. As they dont understand the difference between Blocker and Critical by example.
Hi @AJ,
You can implement this using the priority schemes. Please refer to the article below.
Notes: This feature is available form JIRA 7.6 onwards.
Swathi
@[deleted], I looked at your reply. I am on the Cloud version and the way this following article reads, it appears that this is a feature not supported in the Cloud instance.
@[deleted], I figured out one way to do it. See images attached.
