Jira SSL LetsEncrypt Not working
Benjamin Spence June 28, 2018
Hi, I seem to be having problems setting up SSL for my jira site. I've followed articles but it doesn't appear to start up my jira instance
<Connector port="8443" protocol="org.apache.coyote.http11.Http11Protocol"
maxHttpHeaderSize="8192" SSLEnabled="true"
maxThreads="150" minSpareThreads="25"
enableLookups="false" disableUploadTimeout="true"
acceptCount="100" scheme="https" secure="true"
clientAuth="false" sslProtocol="TLS" useBodyEncodingForURI="true"
keyAlias="root" keystoreFile="/home/jira/jira.jks" keystorePass="mypasswordhere" keystoreType="JKS"/>
Articles I followed:
https://community.atlassian.com/t5/Jira-questions/HTTPs-for-JIRA-with-Letsencrypt/qaq-p/818083
Timothy
June 28, 2018
What is the error what you start your Jira instance?
Benjamin Spence June 29, 2018
29-Jun-2018 16:39:58.517 SEVERE [main] org.apache.catalina.core.StandardService.destroyInternal Failed to destroy connector [Connector[org.apache.coyote.http11.Http11Protocol-8443]]
org.apache.catalina.LifecycleException: Failed to destroy component [Connector[org.apache.coyote.http11.Http11Protocol-8443]]
at org.apache.catalina.util.LifecycleBase.destroy(LifecycleBase.java:302)
at org.apache.catalina.core.StandardService.destroyInternal(StandardService.java:571)
at org.apache.catalina.util.LifecycleBase.destroy(LifecycleBase.java:297)
at org.apache.catalina.core.StandardServer.destroyInternal(StandardServer.java:881)
at org.apache.catalina.startup.Catalina.start(Catalina.java:659)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:355)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:495)
Caused by: org.apache.catalina.LifecycleException: Protocol handler destroy failed
at org.apache.catalina.connector.Connector.destroyInternal(Connector.java:1008)
... 11 more
Caused by: java.lang.NullPointerException
at org.apache.catalina.connector.Connector.destroyInternal(Connector.java:1006)
... 12 more
Timothy
June 29, 2018
That's not the error message. That's the Tomcat shutting down.
Benjamin Spence June 30, 2018
So I've not really seen anything by way of error in the logs. Everything appears to start properly, the port is Listening, but it will not let me connect on https 8443. Oddly enough http 8443 works despite the SSL directives.
I've made some changes to my config that I saw in an article related to an issue on the SSLProtocols variable
 <Connector port="8443" maxHttpHeaderSize="8192"
  maxThreads="150" minSpareThreads="25" maxSpareThreads="75"
  enableLookups="false" disableUploadTimeout="true" useBodyEncodingForURI="true"
  clientAuth="false" sslEnabledProtocols="TLSv1.2,TLSv1.3"
  keystoreFile="/home/jira/.keystore"
  keystorePass="MYPASSWORD"
  keyAlias="root"/>
Timothy
June 30, 2018
You can post your whole server.xml here which will help.
You can also try SSLPoke to test the connection:
Though, I personally prefer:
  • openssl s_client -connect <domain>:<port>
I just saw this error with my latest start up
...I will try the SSL poke and post the full server.xml next. Thanks for the help.
2018-06-30 22:49:00,244 http-nio-8443-exec-4 ERROR anonymous 1369x4x1 - x.x.x.x /plugins/servlet/gadgets/dashboard-diagnostics [c.a.g.d.internal.diagnostics.DiagnosticsServlet] DIAGNOSTICS: FAILED
com.atlassian.gadgets.dashboard.internal.diagnostics.UrlSchemeMismatchException: Detected URL scheme, 'https', does not match expected scheme 'http'
at com.atlassian.gadgets.dashboard.internal.diagnostics.Diagnostics.checkExpectedScheme(Diagnostics.java:52)
at com.atlassian.gadgets.dashboard.internal.diagnostics.Diagnostics.check(Diagnostics.java:31)
at com.atlassian.gadgets.dashboard.internal.diagnostics.DiagnosticsServlet.executeDiagnostics(DiagnosticsServlet.java:82)
at com.atlassian.gadgets.dashboard.internal.diagnostics.DiagnosticsServlet.doPost(DiagnosticsServlet.java:58)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:648)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at com.atlassian.plugin.servlet.DelegatingPluginServlet.service(DelegatingPluginServlet.java:37)
at com.atlassian.plugin.servlet.ServletModuleContainerServlet.service(ServletModuleContainerServlet.java:45)
... 53 filtered
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:21)
... 58 filtered
at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:66)
... 1 filtered
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:64)
... 36 filtered
at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30)
... 10 filtered
... 4 filtered
at com.atlassian.web.servlet.plugin.LocationCleanerFilter.doFilter(LocationCleanerFilter.java:36)
... 26 filtered
at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(MetricsCollectorFilter.java:25)
... 23 filtered
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
30-Jun-2018 22:49:06.039 INFO [http-nio-8443-exec-6] org.apache.coyote.http11.Http11Processor.service Error parsing HTTP request header
Note: further occurrences of HTTP header parsing errors will be logged at DEBUG level.
java.lang.IllegalArgumentException: Invalid character found in method name. HTTP method names must be tokens
at org.apache.coyote.http11.Http11InputBuffer.parseRequestLine(Http11InputBuffer.java:462)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:667)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:802)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1410)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
Full server.xml..
<?xml version="1.0" encoding="utf-8"?>
<Server port="8005" shutdown="SHUTDOWN">
    <Listener className="org.apache.catalina.startup.VersionLoggerListener"/>
    <Listener className="org.apache.catalina.core.AprLifecycleListener" SSLEngine="on"/>
    <Listener className="org.apache.catalina.core.JreMemoryLeakPreventionListener"/>
    <Listener className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener"/>
    <Listener className="org.apache.catalina.core.ThreadLocalLeakPreventionListener"/>
    <Service name="Catalina">
        <Connector port="8080" maxThreads="150" minSpareThreads="25" connectionTimeout="20000" enableLookups="false"
                   maxHttpHeaderSize="8192" protocol="HTTP/1.1" useBodyEncodingForURI="true" redirectPort="8443"
                   acceptCount="100" disableUploadTimeout="true" bindOnInit="false"/>
<Connector port="8443" maxHttpHeaderSize="8192" protocol="org.apache.coyote.http11.Http11NioProtocol"
  keyAlias="root"/>
        <Engine name="Catalina" defaultHost="localhost">
            <Host name="localhost" appBase="webapps" unpackWARs="true" autoDeploy="true">
                <Context path="" docBase="${catalina.home}/atlassian-jira" reloadable="false" useHttpOnly="true">
                    <Resource name="UserTransaction" auth="Container" type="javax.transaction.UserTransaction"
                              factory="org.objectweb.jotm.UserTransactionFactory" jotm.timeout="60"/>
                    <Manager pathname=""/>
                    <JarScanner scanManifest="false"/>
                </Context>
            </Host>
            <Valve className="org.apache.catalina.valves.AccessLogValve"
                   pattern="%a %{jira.request.id}r %{jira.request.username}r %t &quot;%m %U%q %H&quot; %s %b %D &quot;%{Referer}i&quot; &quot;%{User-Agent}i&quot; &quot;%{jira.request.assession.id}r&quot;"/>
        </Engine>
    </Service>
</Server>
Well that is definitely not good.
CONNECTED(00000005)
140735891502024:error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol:/BuildRoot/Library/Caches/com.apple.xbs/Sources/libressl/libressl-22.50.2/libressl/ssl/s23_clnt.c:565:
no peer certificate available
No client certificate CA names sent
SSL handshake has read 7 bytes and written 318 bytes
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
Timothy
June 30, 2018
sslEnabledProtocols? That's for Tomcat 5/6. You should take a look at the Connector tag again against your Jira and Tomcat version.
I'm running Jira 7.10.1, and it says Tomcat 8.5.6
I put SSLEnabled according to this article. Should I just be using SSLProtocol="TLS"?
https://confluence.atlassian.com/adminjiraserver/running-jira-applications-over-ssl-or-https-938847764.html
.....figured it out. A couple things I did wrong (and/or forgot). I removed the SSLEnabled=True for some reason along the way. The second was I had the key alias set to root, which after looking at my confluence set up, I never defined. I saw a key exception error which lead me down that path.. At any rate, SSL is working and I can now go have a beer. Thanks for your help sir!
Timothy
July 1, 2018
No beer for me too? :D
Benjamin Spence July 1, 2018
hahah, definitely, cheers!
