Hello dear community -
I did an automation in JSON to automate the Jira Status Transition:
{ "update": { "labels": [ { "add": "clone" } ], "issuelinks": [ { "add": { "type": { "name": "Cloners" }, "outwardIssue": { "key": "{{issue.key}}" } } } ] }, "fields": { "customfield_10032": { "value": "{{triggerIssue.customfield_10032.value}}" } }, "transition": { "id": "42" } }
The problem that this status transition doesnt work.
Any ideas why?
Thanks a lot in advance!
BR
Tim
Hi @Timur -- Welcome to the Atlassian Community!
Even though the Create Issue endpoint supports immediately transitioning, I recall my experimentation last year showed the automation rule actions for Create and Clone do not support this in the manner they use the endpoint. Instead they always fail with invalid JSON errors.
Instead, you can use the Send Web Request action to call the endpoint and supply your fields. For a short example, this JSON works:
"fields": {
"project": {
"id": "12345"
"summary": "create issue in a different status using send web request",
"issuetype": {
"id": "10001"
"transition" : {
"id": "31"
Hello @Timur
Is this in the context of an Automation Rule? If so, when asking for help with an Automation Rule it will enable us to help you more effectively if you provide:
1. Screen images that show your entire Automation Rule,
2. Screen images showing the details of the step(s) that are not yielding the results you expect,
3. Screen images that show the complete audit log output from the execution of the automation rule.
Can you provide a link to the source material that states you can transition an issue through the JSON code? I don't believe that is actual possible, but would be happy to be proven wrong by seeing reliable documentation that states it can be done.
Hi @Trudy Claspill -
Thanks a lot!
Here ist a screenshot:
Here the corresponding code:
"update": {
"labels": [
"add": "clone"
"issuelinks": [
"add": {
"type": {
"name": "Cloners"
"outwardIssue": {
"fields": {
"transition": {
"id": "42"
"update": {
"comment": [
"add": {
"body": "Thanks for raising {{issue.key}}."
"fields": {
"resolution": {
"name": "Fixed"
In the audits is everything correct..
Looking forward to your answer!
BR
Thank you for those screen images.
"Can you provide a link to the source material that states you can transition an issue through the JSON code? "
We did not find any code, we just wrote it using your guides...
So you mean that it is not possible via automation to change the Transition an Issue + Category? We need it to create automatically new yearly events after we put them to DONE.
Hello Timur,
I have not found a document provided by Atlassian that provides an example of
If you have found such a document, I am asking you to please provide a link to it.
I don't think that the lines of code I marked as bold will work in such a context. I don't think that including "transition" is valid in the JSON code in this context.
"update" and "fields" are the only valid sections according to the documentation for Advanced Editing using JSON in Automation Rules.
"update": {
"labels": [
"add": "clone"
"issuelinks": [
"add": {
"type": {
"name": "Cloners"
"outwardIssue": {
"fields": {
"transition": {
"id": "42"
You could execute a transition of the newly cloned issue by adding the steps shown below:
