Hi Kelly,
If you want to connect with me on LinkedIn, I can pass you along to someone.
https://www.linkedin.com/in/john-funk-92261a38/
Hi John,
Thanks for reaching out. I sent an invite to connect on LinkedIn.
Kelly
Hi @Kelly Flynn
It's Mary from Planyway for Jira
Use the Jira Content Pack for Power BI: This allows you to quickly import Jira data into Power BI to analyze workloads, resolve issues, visualize velocity over time, and more. It's a starting point for building dashboards that can give you insights into your Jira projects.
Connect Jira to Power BI Using a Connector: There are connectors available on the Atlassian Marketplace, such as the "Power BI Connector for Jira," which facilitate no-code integration between Jira and Power BI. This can be particularly useful for exporting data from Jira apps like Tempo, Xray, Time in Status, etc., into Power BI.
Manual Integration via API: For a more customized integration, you can use the Jira API to fetch data into Power BI. This might require more technical knowledge and involves steps like generating an API token in Jira, using the "Get Data" feature in Power BI, and selecting "OData feed" to import the data.
Hi Mary
I've connected using the Jira Rest API in Power BI Desktop and can data out, but get a credentials error once the report is uploaded to the Power BI Service (no matter what connection type/credentials I use).
Is this something you have perhaps seen in the past?
Kind Regards
Dave
got same trouble as yours.
Hi @Kelly Flynn
There is an app for integration called Power BI Connector for Jira, you can try that.
https://marketplace.atlassian.com/apps/1221150/power-bi-connector-for-jira
Hi, thanks for responding. I've requested a trial to this, but I was hoping there was an advanced class that a third party may be offering.
I am having an issue while connecting with Jira from Power BI.
I have followed step by step approach How to Create Data Source - Power BI Connector for Jira Cloud - Alpha Serve (atlassian.net) but in Power BI getting an error. I am able to create Datasource token etc but still an error is returned.
Hello @vishal_bhatia
Please submit a support request to support@alpha-serve.com. - the product team will be eager to help you!
Anna
