For whatever reason jira never shows the images we upload. It only shows the screen shot name. Extremely frustrating. Bitbucket works perfect but lira no so much. Is there a setting that i do not know about.
Any help is greatly appreciated.
Hi @Tim Maler
Do the attachments appear in the issue and just not in comments they are added to?
If the former can you check that JIRA has the appropriate permission to read attachments from your home directory?
/var/atlassian/application-data/jira/data folder
Make sure the person who started JIRA or who is running JIRA has the read permission on this folder.
In both places it just shows the image name. Its odd meaning when you first upload the image it shows but after you click save its just the name.
Please check the directory permission that is indeed very odd.
Can you right click the attachment in browser and inspect the element. Switch to network tab and check the response when you refresh the page?
This could help hint what is going on, also check your log for errors.
