Jira automation: Cron condition every 2 weeks
Sergio Montávez
Hi, I'm creating a Jira Automation rule and I want it to be launched on each Monday alternatively, in other words the first day of a 2 weeks timeframe.
I've checked the CRON documentation but cannot find the solution: https://support.atlassian.com/jira-software-cloud/docs/construct-cron-expressions-for-a-filter-subscription/
Thanks!
Ismael Jimoh
January 26, 2021
Hi @Sergio Montávez
I believe the standard cron doesn’t provide such a feature and you may need to look at a more complex expression which Jiramay still not support.
Have a look at this article: https://coderwall.com/p/yzzu5a/running-a-cron-job-every-other-week where the author shows running a cron expression every other Monday. Note still that this depends on if Jira supports expressions in your cron job.
If anyone is more familiar, I hope you can help here.
Sergio Montávez
Thanks for the answer, unfortunately, some of those expressions are not supported by Jira according to their documentation: https://support.atlassian.com/jira-software-cloud/docs/construct-cron-expressions-for-a-filter-subscription/
Cengiz Akyildiz
This post seems to be old, but still wanted to share if it helps someone else.
I have similar case for a rule that should run every 3 weeks on Mondays 9am. So I ended up creating a cron job that runs every Monday at 9am, however I tried to use a condition that will result true every 3 weeks from the base date you give. For example my base date is 2022-11-14 which is again Monday I've used below expression:
{{#=}} {{now.diff(now.withYear(2022).withMonth(11).withDayOfMonth(14)).abs.days}} % 21 {{/}}
Above value would return zero for every 21 days (3 weeks) starting from the base date and you can let the rule do whatever action it needed. Tweaking with the numbers you can set any fixed frequency. The expression might be optimized further, but it simply runs.
And also I still don't get it why A4J for DC still does have a cloud-like fixed schedule feature, makes life easier for Jira admins ;)
Like Nadezhda Alshafi likes this
Stian Nielsen-Man
June 10, 2023
Hi @Cengiz Akyildiz , where do you use the expression – it it in the subscription cron field? It doesn't seem to allow me to put curly brackets in that field.
Cengiz Akyildiz
Nope, it is in the Advanced compare condition...
