Hello Jira community,
I've been going through some automation on Jira, some of them worked for me but this one I'm trying to figure it out It's causing me problems.
The automation I want is this: If UAT status due date is changed to 2 weeks
then: If no update on the ticket for this timeline, move the issue to Release, change the due date to one more week and comment @ assigne please email the customer.
then: If no update on the ticket for this 1 week email the reporter and move the ticket to done.
So I'm able to change the Status from UAT to Release and if no update on the ticket in those 2 weeks and also able to comment and tag the assignee.
The problems I'm facing is
1) due date It's not changed to one more week.
2) also move it to done and email the reporter not working.
P.S
- I'm testing it for minutes instead of weeks to see If it's working
- to change the due date to one more week I've used three different : {{now.plusWeeks(7)}}
{{now.plusDays(7)}}
{{now.plusBusinessDays(1)}}
See screenshots of the three rules:
Hi @Tomi
First thing I would recommend is to check that any rules which are triggered by other rules have this checkbox ticked.
I see from your first screenshot that you trigger a transition, which is used in the trigger for the second rule, so perhaps this is causing the problem?
For your third rule where you send the email, are there any errors in the audit log? Or is the rule simply not triggering? If the rule is triggering, is there definitely a reporter on the triggering issues to send the email to?
Great, glad you've got it sorted!
@Callum Carlile _Automation Consultants_ I have one problem though.
If the due date is e.g. 3 june/2022 and automatic due date need to change it to one more week so 10 june/2022, It's not working.
{{now.plusBusinessDays(6)}} is only taking the current date (today 26th of May) and changing it to 3 of June.
@Tomi If you slightly amend your smart value to {{Due Date.plusBusinessDays(6)}} then this should work
