I have an existing automation rule that will set the Story to DONE when all the Sub-Tasks are set to Done (When all sub-tasks are done → move parent to done). Works perfect. We now have administrators using the Cancelled status in their Sub-Tasks, so I need to adjust the automation rule.
When: Issue is transitioned to Done
For Parent - Status does not equal Done. And: Sub-tasks match "status = done". Related issues = Sub-tasks. Condition = All match specified JQL.
Then: Transition the issue to Done.
When I change And: Sub-tasks match "status = done OR status = cancelled" or "status = done AND status = cancelled" the rule fails to transition if the sub-tasks are set to cancelled. If one sub-task is set to cancelled and one sub-task is set to done the rule fires appropriately. I have tried many possible variations in changing\adjusting the "And:Sub-tasks match" field.
Is there something specific to the Cancelled status?
Thank you for your help.
Hi @Bill Ewald - I would consider changing your sub-tasks match condition to status contains Done/Canceled or if you're using JQL status IN (Done,Canceled)
Validate query was successful. Automation rule did not work when testing against two sub-tasks that were change to cancelled. Not 100% sure I set the changes correctly.
Related issues - Sub-tasks
Condition - All match specified JQL
Matching JQL - status in (Cancelled, Done)
Can you please share a screenshot of your rule and audit log?
Audit log just reads Config Changed. No other details.
That tells me that the rule has not triggered since you changed the config. You need to transition a sub-task.
did you try the "statuscategory"?
Ok - So your trigger is still only looking for when issues are transitioned to Done. You'll need to include Cancelled in your trigger.
Yes I moved my two sub-tasks from Cancelled to In Progress and back to Cancelled. The validate query returned 1200 results but the rule did not fire. I am working on statuscategory now.
Attempted statuscategory= done AND statuscategory= cancelled. It appears I only have TO DO, IN PROGRESS, and DONE. When I run my JQL search:"project = ITOPS AND statusCategory = 3" it returns DONE and CANCELLED status results.
Did you see my last comment? You'll need to update your trigger to include Cancelled.
Also - statusCategory is indiscriminate of individual statuses as it relates to the status colors you see on the screen (Gray = To Do, Blue = In Progress, Green = Done). So assuming both your Done and Cancelled statuses are green, it would be statusCategory = Done
Mark I did see your last comment. Trying to figure out where to add Cancelled.
@Jack Brickey @Bill Ewald can you pls help on this
I've encountered an issue with a Jira Cloud automation rule, and I'm hoping someone can help me resolve it.
I've set up an automation rule to count field changes in an issue from Monday to Friday. However, it appears that the rule is also counting changes on Saturday and Sunday, which is not the intended behavior.
Is there a way to configure the automation rule to exclude weekends (Saturday and Sunday) from the count? I want it to operate strictly on weekdays.
Any guidance or suggestions on how to achieve this would be greatly appreciated.
Thank you in advance for your assistance!
@Saraswathikotala , please post a new question in the community. This will ensure you get the most eyes on your question. In this post, only those that were engaged are seeing your question.
I would use this...
statuscategory = done
The reason being, if you ever add another "done" status it will still work.
I will adjust and test the rule. Will return the findings to you. Thank you!
